January 25, 2020
eSIM till mitt 3 kontant?
  • January 25, 2020
  • 408 visningar
How do I create eSIM for my 3kontant? My 3kontant nummer is registered with my personal number ; when I go to MItt3 there is no option to order/create eSIM; however I see eSIM option for my postpaid number.
Bäst svar av Jocke
Welcome to 3Community @hshahzad.
To be able to order a eSIM to your 3Kontant you have to contact our customer support.
Jocke
January 27, 2020
hshahzadTrådskapare
January 27, 2020
Thanks for your reply. I have an additional question.
When I install eSIM then what happen to my physical SIM; can I go back to my physical SIM? Or it is deactivated?
Jocke
January 27, 2020
When you activate the eSIM your physical SIM will be deactivated.
