I have dual SIMs Swedisj 3 and USA ATT&T. When I am abroad in the USA how can I check texts, and voice messages people have left on my Swedish number?
If you have 3Världen you can just use your phone as normal when in the US. Calls and SMS to Sweden och the US will be charged according to your 3 plan (most likely included in the plan so you won’t pay anything extra) and up to 60 GB of internet is included as well.
