no roaming in Turkey
  • June 27, 2023
  • 182 visningar
Hey! I have a problem. I am in Turkey right now, and for some reason I have no roaming. My mother and sisters works perfectly. However I have no internet, no sms and even calls are unstable. I had used to Data in Lebanon, which costs, and that’s fine. But what is the issue and how can I access my roaming again?
Thanking you in advance, Olga Babkina.
Forum|alt.badge.img+40
  • June 29, 2023
Hello, @Olga Babkina  Are you still experiencing problems with the roaming or is it working as it should now?
/FHello, are you still experiencing problems with the roaming or is it working as it should now?
Does your mother and sister also have 3 as an operator?
You can see if you log in to mitt3 in the app or browser, how much surfing has been used up. If it could be that it has run out, but then you should have received an SMS about that too.
Depending on whether you have Android or iPhone. So you can go to settings and mobile network and choose manually. To see if it works better by choosing another operator's roaming network.
