October 16, 2023
number transfer
  • October 16, 2023
  • 332 visningar
Hello!
I made a new subscription with the request to transfer my existing number. According to your employee it should happen, seems to have been activated with a new number. Should I expect the change to take place in the following days or does it require any additional actions for that?
@Lefteris Hi,
a number transfer usually takes place within 3-5 business days. You should have gotten a text message to your old number (the number you want to move) with a transfer date, or information on why the transfer was not possible to arrange right now. Did you get that?
@Lefteris Hi,
LefterisTrådskapare
October 17, 2023
I received a text. Everything is in order now, thank you!
