Svar
5G Coverage in Limhamn
  • November 26, 2020
  • 106 visningar
I ported my number from Tele2 hoping that I would be able to use 5G on my new iPhone. But unfortunately, I don’t even get a proper signal at the place I live (the coverage map shows very strong 5G signal!!)
The signal bars disappear very frequently.
Could someone confirm the correct settings to get a strong 5G? Or, is that just non-existent?
Can I go back to Tele2? At least I used to get a strong 4G.
Hi,
as always the network coverage can be different, depending on where you are in relation to the cell site. What you can do, if the 5G does not work for you, is to deactivate 5G and see if the 4G-signal works better for you.
If that doesn't work better, contact 3 customer care and they'll be able to look at it further for you. You can call them on 0735 300 400 Monday to Friday 08am - 7pm.
  • November 26, 2020
Hi,
