November 30, 2018
Memory card NM for Huawei mate pro.
  • November 30, 2018
  • 188 visningar
Where can I purchase this new type of memory card made by Huawei. NM card?
[Redigerat] - Ämnet har flyttats till smartklockor och tillbehör
    Bäst svar av Chipsgeneralen
    Hi!
    Im not sure if the stores of 3 carry the Nano memory card but if not you can always buy them from for example Webhallen. There is quite a lot of online/physical stores that sell them.
    Hopefully this have helped 🙂 Take care!
    Hi!
