October 31, 2021
Lost SIM card
  • October 31, 2021
  • 276 visningar
Hi unfortunately
lost my hasbend simcard
and this phone number is <removed>
// Redigerat // - Ämnets text har redigerats då delar inte följde våra riktlinjer
Hi , if you have lost your sim-card then u need to contact “3 “ store or support on telephone to get a new one .
It goes faster if you go to a local 3 store and they will help you quickly . And you need ID ,driver license or something thats tells it is you .
Best regards F
@Amir Algomaa
@Amir Algomaa Hello,
as @frodrik91 says, you will need a new sim-card which you can obtain by contacting Three customer service or by visiting a Three-store. You can also order one through “Mitt3” - and if your phone supports eSIM you will get a QR-code presented directly which you can use to activate the eSIM in your phone right away.
