October 3, 2022
Prepaid number porting
  • October 3, 2022
  • 310 visningar
I am planning to port my prepaid Telenor to tre. Will I be able to retain my balance after porting?
Bäst svar av frodrik91
@Sudeep
It will not be able to follow, the deposited money is with Telenor and can be used up there. I assume you have a cash card with them, if they offer it.
With 3, you will start over with any unbound subscription & the same number if you want to transfer it.
Hope that answers your question.
Sincerely, F
Hello🙂, @Sudeep
If I understand you correctly, you are thinking of changing from Telenor to 3 & wondering if you can move with your phone number? A simple number transfer. Or do you mean something else?
It is absolutely possible to port a number from one operator to another.
Etc. F
SudeepTrådskapare
October 4, 2022
Hi @frodrik91 😀. Thank you for your response. What I want to ask is that I currently have 500kr balance in my prepaid Telenor number. If I port to Tre, will I have the same balance (500kr) in that number?
@Sudeep
Sincerely, F
SudeepTrådskapare
October 4, 2022
Thank you @frodrik91 for your answer.
