mobile network not working
  • August 6, 2024
  • 9 svar
  • 107 visningar
Hello,
I receive problem with my mobile network. I often get ! This next to the sim card at the top and internet stops working. It comes back after resetting sim card which takes time. Any ideas?
9 svar
Forum|alt.badge.img+18
  • Hjälte
  • August 6, 2024
Which phone? Which symbol? Can you include a screenshot?
It is oneplus 7T and symbol is "!". I don't have screenshot.
  • Hjälte
  • August 6, 2024
I can’t find that symbol in the models manual.
This one
  • Hjälte
  • August 6, 2024
Ok, that means “limited acces to network”. Is mobile data on? Does your plan have data left?
Yes it is on and I have unlimited data. When this comes up I have to restart sim card otherwise it does not work at all.
  • Hjälte
  • August 6, 2024
Seems like a faulty sim-card then. Try cleaning it and maybe order a new.
Thank you. I will try to do that.
  • August 6, 2024
@Eimantas Butkus Do you have two SIM-slots? Try to change the slot and see if it works better.
