May 1, 2020
Tre utlandet
  • May 1, 2020
  • 289 visningar
Recently I was abroad. Tre utlandet worked fine. It was only for 30 days. I wish you increase to 60 days.
Maybe you can charge some money to have it for a longer period than 30 days.
Hi,
as of today 3Världen is valid for 30 days abroad, and after that you'll get charged according to the current price list, which can be found here.
Due to Covid-19 some prices are changed, more information can be found here (in Swedish). If you are abroad right now, you can also contact customer care and they'll look into all specific cases and see if there are any solutions.
Hi,
DurdansTrådskapare
May 4, 2020
Thanks for the reply.
What I said was it should be possible to have more than 30 days.
It is fine that they gave me 30 days.
Maybe they can charge some money and give another 30 days. I was travelling more than 30 days.
Now I am back in Sweden. When I travel it is always 8 to 9 weeks journey.
I hope Tre will consider my proposal.
                          Durdans
Hi @Durdans!
I totally understand if you often do longer visits than 30 days, and therefor you need a longer solution. Sorry to say, but we only have 30 days for this service, and there isn’t a way to prolong it. In most countries you can fill your subscription with a temporary amount of data and calls, but it isn’t free. You do that via “Mitt3” :slight_smile:
DurdansTrådskapare
May 4, 2020
You can ask to pay some money grant another month or so.
