October 11, 2018
Roaming abroad in the US
When using only wifi while in the USA to surf, Instagram, Facebook, WhatsApp, send photos; no messages no telephone calls, is there a cost? and if so why, when I'm using only wifi?
Tristan
Hi Michael!
If you will not be using cellular data, send any text messages through your cellular connection or make any telephone calls then there should not be any costs for you while in USA.
WiFi is not something which Tre can bill you for but be aware of the fact that the feature WiFi calls, if it is supported and works in the USA, will be charged according to the rate for international usage for a normal cellular telephone call.
Have a nice trip. : )
Tristan
Hi Michael!
