December 6, 2025
Connection issue
Two months ago, I started having problems with my Wi-Fi connection. Sometimes it works, and sometimes it doesn’t work at all. Of course, the bills are paid on time, so this shouldn’t be happening. I contacted support earlier, and they advised me to move the router closer to the window and restart it there. I did that, but it didn’t help, so I don’t know what else could be causing the issue.
Limpen
LimpenSvar
December 9, 2025
Hi ​@Yulia, welcome to 3Community! 👋🏻
Sorry to hear that the WiFi isn’t working as expected.
I recommend you contact our customer service again for further troubleshooting. They can also submit a fault report if your problem can’t be solved through regular troubleshooting.
Limpen
LimpenCommunity ManagerSvar
December 9, 2025
