Autogiro - Still receiving paper invoice fee
  • January 20, 2021
  • 152 visningar
I applied autogiro in November and it works well in December.
But now in January, I got a paper bill again and have to pay 50kr extra!!!
Could you explain why it happened like this?
I don’t want to pay for this 50kr!!!
Best regards,
Huan
Bäst svar av Emanuel
Hello @Huan
It sounds like you accidentally applied for Autogiro with paper bill. There are two options. One with sms and Autogiro. And one with Paper bil. If you contact our customer service they can change this for you.
Emanuel
Forum|alt.badge.img+9
  • Pensionerad Moderator
  • January 21, 2021
Hello @Huan
  • January 21, 2021
Thanks for your reply, but why last time it goes automatically through my bank account without problem? Crappy system!
  • January 21, 2021
Now I saw I was not alone, other people also encounter the same problem!!!
  • January 21, 2021
@Huan What you've gotten is probably not a invoice itself that needs to be paid manually, the amount will most likely be charged to your account at the due date of the bill. It’s described on the invoice itself if you need to pay it manually or not.
When signing up for “autogiro”/direct debit you can choose to either get a physical invoice with information about the amount for each month - or to get the amount that will be charged via a text message. Whats probably happened in your case is that you successfully signed up for autogiro, but have chosen to get a paper invoice anyway.
Customer care can help you change this. Customer care can also help you to check if you need to pay the bill manually or if it will be charged through direct debit.
