sep. 13, 2022 10:17 fm UTC
apn
Hello,
We are trying to use our SIM card with a 4G module in Windows 10 operation system for testing. We need to set up APN manually. Could you please provide us APN settings for the sim card.
Best Regards,
Gökcen Özcelik
Younes M
3Medarbetare
sep. 14, 2022 6:01 fm UTC
Hello @gokcen, Welcome to 3Community 😀
Here you have the APN settings for the simcard for broadband, if you want the settings for regular phone use you change the APN to data.tre.se
If you have any further issues regarding the APN, then you can contact Tres customer service here .
APN for router (Module)
Namn: 3
APN: Bredband.tre.se
Proxy: lämna tomt
Port: lämna tomt
Användarnamn: lämna tomt
Lösenord: lämna tomt
Server: lämna tomt
MMSC: http://mms.tre.se
MMS-proxy: mmsproxy.tre.se
MMS-port: 8799
MCC: 240
MNC: 02
Verifieringstyp: lämna tomt
APN-typ: default,supl,mms
APN-protokoll: IPv4
APN-roamingprotokoll: IPv4
Younes M
3Medarbetare
3Medarbetare
Namn: 3
Proxy: lämna tomt
Port: lämna tomt
Server: lämna tomt
MMS-port: 8799
MCC: 240
MNC: 02
APN-protokoll: IPv4
