March 26, 2023
No network available in India
Hi,
I am in GOA, India and couldnot connect automatically to any of the network. When I try to select manually its say forbidden and doesnt connect. I am not able to get any SMS, phone or internet.
Appreciate how the issue can be fixed.
@RRS Hello,
does it work for you now? Have you tried to restart your phone and keep it off for 10 minutes?
If not, can you try to select any of the following networks: Vodafone-Kerala, Airtel, Jio or Reliance. Jio or Airtel should be the best options of these.
@RRS Hello,
Elin
March 28, 2023
Hello @RRS and welcome to 3Community!
Is this still a problem for you? 🤔
If yes, I recommend you to follow “Pettersons” suggestions above and if that doesn´t help, you´re more than welcome to write to us again. 😊
